TractorLinks.com
Order Ford 640 Parts Online
Re: 640 ford govenor hunting problem
NNP
02-24-2014 04:02:07
sounds lean
take a look at your plugs to check your mixture
carb adjustments can/should show a big difference in how it runs.
If they don't, check your carb and fuel-intake track for restrictions or air leaks
you say it runs well under load, but will it go from idle to full throttle in gear, all at once with no stumbling? If it stumbles, usually a lean condition.
flyball and flyweight governors take a different governor spring assembly. right one?
If it has been replaced to a flyweight style, make sure your front
pulley bolt is VERY tight.
