TractorLinks.com
Order Ford 640 Parts Online
Re: 640 ford govenor hunting problem
old
02-17-2014 09:18:16
Does choking it help or hurt it. If it helps it is running to lean if it hurts to rich either one can cause that problem as will sloppy linkage I.E. pin holes worn. Plus when was the last time you check the air cleaner a clog one can cause odd problems
MNGB
02-17-2014 11:03:17
 Re: 640 ford govenor hunting problem in reply to old, 02-17-2014 09:18:16
Also check the compensator spring on the throttle linkage its the spring that attaches the throttle rod to the governor arm, on my tractor it was set to light/weak and it hunted particularly with little or no load when pulling it was ok, drove me about half crazy till I figured it out.
GB in MN
