TractorLinks.com
Show Parts for Model:
Re: 3500 rear axle shaft pic for wear
RodInNS
02-16-2014 18:37:01
You may be correct... but I don't recall seeing much play in the 3000 I dealt with. I remember the hub will roll around some on the cone but as I recall the bearing is an interference fit on the shaft.
Rod
Bern
02-16-2014 19:15:36
 Re: 3500 rear axle shaft pic for wear in reply to RodInNS, 02-16-2014 18:37:01
Yes, the bearing cone and roller assy is most definitely a press fit on the shaft, however, if the hub is not bolted to the axle housing, it is free to flop around a little. In other words, there is nothing to force the hub (and installed bearing cup) towards the cone and roller assy until the hub is bolted to the trumpet housing. A fairly tight seal might be what made it feel snug.
I felt it necessary to correct you here so that others don't think that a problem exists where there is none. End play of either side cannot be checked until BOTH axles are installed.
