I've seen a couple times either on here or the other YT forums about people keeping the clutch pedal depressed so the clutch won't stick if left unused for awhile. Instead of blocking or wiring the pedal down, someone showed me this years ago. Just depress the pedal with your hand and then put a 3/8" nut between the adjusting bolt head and casting of tractor. Works perfectly. When ready to use the tractor, just put your hand under nut, depress pedal, nut will come free, and your ready to go. Hardest thing I've found is finding which pocket I put the nut in to put it back when I'm done for the day.
