TractorLinks.com
Order Ford 4000 Parts Online
Re: Just purchased 1962 4000 with SOS problems
Al Baker
02-16-2014 16:48:24
My experience with a SOS that wants to stall when pulled from park is a sticky valve body. Most times it will act better after being warmed up awhile. I was advised to mix 15/40 and dextron IV for fluid. Old ford SOS factory guy turned me on to this. Seams the high detergent helps flush the tranny clean to help the valves from getting sticky. Remember they are cam opened, but spring closed. doesn't take much to have more than one trying to send oil to different clutch packs at once. I am no expert, but have repaired many SOS trannys. This issue is common. Good luck. Al
Jason in michigan
02-16-2014 17:07:09
 Re: Just purchased 1962 4000 with SOS problems in reply to Al Baker, 02-16-2014 16:48:24
Thanks Al I'll be checking that valve body out next weekend. By the way the injectors that you rebuilt back in the late fall cured my problem on the 7000 it runs great now!
Jason
