Jason in michigan
Just purchased a 1962 4000 row crop with some SOS problems that I'm trying to diagnose. First when I got it home it wanted to labor and stall out in r1 and r2 and a few forward gears then I changed oil and properly adjusted the bands by the manual and all gears worked great then went to back it into the shop and same thing again started in reverse but labored and stalled. Then I locked it out pushed it back in the shop and happen to pull the dipstick out and the SOS fluid is over filling the hydraulic fluid. Okay any suggestions on what I should do next to figure my problem out I believe its something minor since after fluid change and band adjustment it worked great.
Jason
Jason
