Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Live PTO Versus 2 Stage Clucth
02-16-2014 09:20:35
Various terms to cover various products. For what I've learned and remembered Live power indicated you could start and stop tractor ground movement with out stopping the PTO. This is real handy if you're baling, running a combine, corn picker or other type of harvester. Some of the early live power tractors simply added a clutch somewhere in the driveline after the PTO to allow starting and stopping but maybe not gear changes or even turning the PTO on or off without stopping the tractor. Some manufacturers came up with what is known as independent PTO meaning you can start or stop tractor ground speed with out effecting the PTO as well as turning on or off the PTO without effecting the ground speed. Or to put it another way the PTO and traction drives are completely separate or independent of each other. Another variation was the two stage clutch where the same pedal has two positions, one for the traction drive (usually 1/2 way) and another for everything (traction AND PTO all the way down). The two stage clutch seemed to be the way Ford and Massey Ferguson tended to do things, the only older Fords I ever saw with independent PTO were the old Select-O-Shifts. According to Tractor House data if you've got an 850 you have transmission or non-live/independent PTO. On that series the 820 had no PTO or 3 point ot Hydraulics, the 850 3 point, hydraulics & transmission PTO and the 860 3 point & live PTO (IIRC a dual clutch).
02-16-2014 11:59:03
 Re: Live PTO Versus 2 Stage Clucth in reply to wisbaker, 02-16-2014 09:20:35
There was also the system A/C used with a foot clutch that stopped every thing and a hand clutch that only stopped forward movement of the tractor but the PTO kept running. Of all the live PTO set ups Oliver by far had the best set up with a PTO clutch so the engine/trans clutch had nothing to do with the PTO
02-16-2014 14:30:26
 Re: Live PTO Versus 2 Stage Clucth in reply to old, 02-16-2014 11:59:03
This got me do wondering, old. I have three COOPs (Cockshutts before they became Olivers) and I recently got a 1550. Independent PTO on both are very similar. Who had it first? I always thought it was Cockshutt with the 1946 30s. I'm not familiar with the two digit Olivers.
02-16-2014 14:35:48
 Re: Live PTO Versus 2 Stage Clucth in reply to Mike(NEOhio), 02-16-2014 14:30:26
The way I understand it was that at that point in time Cockshutt and Oliver had some sort of business dealings with each other and due to that they both came out with the independent live PTO at the same point in time
02-16-2014 15:11:35
 Re: Live PTO Versus 2 Stage Clucth in reply to old, 02-16-2014 14:35:48
OK. I've seen Cockshutts at shows that were two digit Olivers dressed in red. But I never knew if they had independent PTO. Either way they were years ahead of IH and JD.
02-16-2014 15:21:45
 Re: Live PTO Versus 2 Stage Clucth in reply to Mike(NEOhio), 02-16-2014 15:11:35
Oliver was years ahead of pretty much all the tractor companies in many many things. But behind as for a hyd lift system like Ford 3 point
