TractorLinks.com
Show Parts for Model:
Re: 3500 rear axle shaft pic for wear
RodInNS
02-15-2014 19:32:57
The axle looks fine to me. Stand it on it's flange... then grab the hub and see if you can move that vertically. If it's got any movement, break it down and inspect/replace the bearing.
The axle nut is a nyloc and can be reused if you don't bugger it up. If you do or it looks poor... you can get one from A&I for about 40 bucks.
Don't waste your time with foolish pullers when trying to remove the bearing either... pop a few of the studs from the flange so you can get it properly situated in a press and push the shaft out. Just make sure that you support the hub correctly.... and that will take some work. New bearing is heated to ~400 deg and dropped in place.
Rod
Bern
02-16-2014 16:07:20
 Re: 3500 rear axle shaft pic for wear in reply to RodInNS, 02-15-2014 19:32:57
Rod,
I'm going to have to disagree with you on your statement about vertical end play of the hub. Even when the bearing is new and the nut is tight, as I recall, there is noticeable end play of the assembly that makes it seem like something is really wrong. It's not until you install them both in the tractor and properly shim it that end play becomes what it should. Those axle shafts butt up against each other inside.
RodInNS
02-16-2014 18:37:01
 Re: 3500 rear axle shaft pic for wear in reply to Bern, 02-16-2014 16:07:20
You may be correct... but I don't recall seeing much play in the 3000 I dealt with. I remember the hub will roll around some on the cone but as I recall the bearing is an interference fit on the shaft.
Rod
Bern
02-16-2014 19:15:36
 Re: 3500 rear axle shaft pic for wear in reply to RodInNS, 02-16-2014 18:37:01
Yes, the bearing cone and roller assy is most definitely a press fit on the shaft, however, if the hub is not bolted to the axle housing, it is free to flop around a little. In other words, there is nothing to force the hub (and installed bearing cup) towards the cone and roller assy until the hub is bolted to the trumpet housing. A fairly tight seal might be what made it feel snug.
I felt it necessary to correct you here so that others don't think that a problem exists where there is none. End play of either side cannot be checked until BOTH axles are installed.
DavidLA
02-16-2014 06:39:10
is the race and bearing one piece, or are they separate? i can't tell from the parts diagram/list. if its separate, do i pull the race too, or just replace the bearing?
thanks
RodInNS
02-16-2014 11:42:29
 Re: 3500 rear axle shaft pic for wear in reply to DavidLA, 02-16-2014 06:39:10
It's a standard tapered roller bearing. It will be supplied as a set with cone and cup. Replace both.
Rod
