TractorLinks.com
Show Parts for Model:
Re: SOS Trans Work
jaluhn
02-14-2014 19:58:00
You are right, my memory is likely faulty as to which parts are which.
I am not asking for help troubleshooting as it has been established to my satisfaction that the forward most band (B1?) in the transmission is not applying and it is almost certainly due to a mechanical issue in the band or linkage. I believe this was concluded with help from this board.
My question is that assuming that the troubleshooting is correct, how likely am I to be opening a huge can of worms by trying the open this thing up to replace / repair the band? Based on the manual I think I can fairly easily pull the main parts out of the case to access the band, repair it and put it back together.... but I also know that what looks easy and straightforward in the book may or may not be that way in practice - hence asking for thoughts from those more experienced than myself.
That list of ratios posted does seem to match the ones I have that don't work.
Dean
02-14-2014 20:08:30
 Re: SOS Trans Work in reply to jaluhn, 02-14-2014 19:58:00
Fair enough but I would not even think about opening it up without complete diagnosis.
As I said earlier, it could be a simple external fix but it is necessary to know what ratios are not functioning to diagnose.
Dean
jaluhn
02-14-2014 20:16:48
 Re: SOS Trans Work in reply to Dean, 02-14-2014 20:08:30
Oh, of course. Had my share of problems that could have been fixed a much easier way to jump into major work without being sure. :lol:
I am 95% sure that list is correct for the ratios that are not working, and I recall narrowing it down with high confidence to a mechanical problem in that band - including testing hydraulic pressure to the servo IIRC.
jaluhn
02-14-2014 20:00:19
At the moment neither the tractor or any of my manuals are readily accessible to me, hence the reliance on memory - I'm in the middle of moving, however I do have the time to research and plan what work I need to get done when I do again get a good place to tear stuff apart. This is why I don't have clearer more accurate info to post.
Thanks!
