1971 Ford 300 Carburetor
Aztmbrwolf
New User
Rebuilding Holley R12-3589B 1000 on 71 Ford 3000.
Anyone have exploded view of float and float spring assembly. Rebuild kit had no drawing or instruction. My manual does not show assembly view. Any assist would be greatly appreciated. Thanks. can send to [email protected] if needed
(quoted from post at 05:09:20 12/18/13) Rebuilding Holley R12-3589B 1000 on 71 Ford 3000.
You have mail,,, set the float on the low side :wink: Make sure the gasket tween the carb and metering body fits dead nutz trim as needed, most are oversize on the ID and hit the carb body and causes a mis-aligment it pushes the gasket toward the float side and away from the air horn,,, make sure the check valve for the accelerator pump checks one one way... The pump has to move freely in the bore....
STOP and take the time to confirm this and you will become a Holly lubber if you don't you will be welcomed into the Holly hatters club with open arms....
