I recently purchased theHydraulic Adapter Kit Part Number HV4902. I attached it to my ford 2600 and then plumbed in an open center valve with power beyond. I want make sure I have it plumbed correctly .I connected 3 hoses in this manner:
I connected a hose from the power port on the adaptor kit to the in port on the one spool valve.
2. I connected a hose from the return port on the valve to the return port on the hyd. adaptor block.
3. I connected a hose from the power beyond port on the open center valve to the power beyond port on the adaptor plate/block.
my 3 point works and the valve body works so i assume everything is ok.
However something in the back of my head says maybe i should have connected things differently with the power beyond ports and the power/in ports. Thanks.
