Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 851 d hyralic lift does not work
Kurt-NEPA
12-12-2013 15:07:10
Hi Chuck, welcome to the forum.
Have you bled the air from the pump? That's where I would start. There is a pipe plug on the top of the front of the pump. With the tractor running, slowly loosen the plug until oil comes out around the plug. If you see bubbles, let it be for a bit until the bubbles stop. Then tighten the plug. See if that helps.
chuckinnc1
12-12-2013 15:15:31
 Re: 851 d hyralic lift does not work in reply to Kurt-NEPA, 12-12-2013 15:07:10
YES THE PUMP WAS BLEED
soundguy
12-12-2013 17:46:24
 Re: 851 d hyralic lift does not work in reply to chuckinnc1, 12-12-2013 15:15:31
with arms pined or chained, hauge in, and lift ran up at high idle.. 300 psi is it?
