TractorLinks.com
Show Parts for Model:
Re: Select-O-Speed takes long time to engage in reverse
Dean
11-27-2013 23:05:34
It is not uncommon for late model S-O-S transmissions to delay upon reverse engagement but a full minute is excessive.
You should use only CNH 134D oil or quality equivalent. Do not use ATF.
When did you last change the filter?
When did you last adjust the bands?
Late model S-O-S transmissions are just about bullet proof PROVIDED routine maintenance.
Dean
Nicole S
11-28-2013 07:36:17
 Re: Select-O-Speed takes long time to engage in reverse in reply to Dean, 11-27-2013 23:05:34
I have not serviced the fluid yet, I purchased the tractor about 2 years ago from the original owner and followed his advice to use ATF. Once I started having issues I purchased a service manual and read about the fluid and also adjusting the bands. I will start with the fluid and go from there. I was wanting so expert advice so thank you! It's a great tractor so I was hoping I could fix it.
Tequila
11-28-2013 08:13:15
 Re: Select-O-Speed takes long time to engage in reverse in reply to Nicole S, 11-28-2013 07:36:17
Reading the manual can instill some apprehension , but it's pretty straight forward taken one step at a time. I would suggest draining all fluid from the trans. Clean the pickup screen and install a new filter and fresh UTF fluid that meets ford specs. Warm tractor up to operating temp and adjust bands following manual precisely. As Larry says, it sounds like band three, but adjust them all in the correct sequence. You should then be good to go.
