Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: vertical exhaust ford 900
austin carpenter
11-27-2013 17:47:20
Is there a better kit than this one? Something more original
Will Gumbert
11-27-2013 18:47:42
 Re: vertical exhaust ford 900 in reply to austin carpenter, 11-27-2013 17:47:20
For something more original you could go to New Holland (or Messick's) for part# 86534432 which is a steel elbow that has a flange welded to it that bolts onto the cylinder head. This then connects to the muffler outlet and clears the hood and provides the vertical direction. Then all you need is the vertical pipe, clamps, and rain cap. (The above part# was provided by showcrop in an earlier post about a similar subject.) This part costs about $65-$67 so be prepared. I don't think this site sells it but you should check.
In my case I needed to use a long bolt in the bottom hole and some washers behind the flange to get it to be exactly vertical. -Will
This post was edited by Will Gumbert at 18:53:41 11/27/13.
Dean
11-28-2013 05:38:24
 Re: vertical exhaust ford 900 in reply to Will Gumbert, 11-27-2013 18:47:42
Nice looking 961, Will.
I have the same aftermarket manifold on my 55 860 and the same vertical exhaust elbow/bracket for my 961.
Dean
Will Gumbert
11-28-2013 06:04:50
 Re: vertical exhaust ford 900 in reply to Dean, 11-28-2013 05:38:24
Thanks, Dean. I have a '62 4000 with a loader that has the same exhaust system. I know this works out with the x01 and aftermarket manifolds, but would it work with the original x00 manifold?
Did your 860 originally have a vertical exhaust? Did Ford offer a vertical exhaust for the x00 tractors? -Will
Dean
11-28-2013 06:36:06
 Re: vertical exhaust ford 900 in reply to Will Gumbert, 11-28-2013 06:04:50
My 860 had an aftermarket vertical exhaust on it when I bought it but I converted it to horizontal shortly thereafter. I used it to mow and was routinely driving under tree limbs.
I believe that Ford offered the vertical exhaust for the 00 series but, I believe the cast elbow was used.
I see no reason why the large muffler elbow, muffler and remainder of the large exhaust could not be used with the original manifold whether 134 or 172 engine.
I have the large (horizontal) exhaust on my 64 4000 S-O-S and do not find the sound as pleasing as the sound of my 860 with small horizontal exhaust.
Dean
WayneIA
11-27-2013 19:10:49
I think the elbow you are referring to only works on the 172 engine built after 1958 for the 8 and 901 series tractor with the bigger 1 5/8" exhaust pipe. I guess I am not aware of any 1 1/2" vertical exhaust built like the original
Will Gumbert
11-27-2013 20:41:52
 Re: vertical exhaust ford 900 in reply to WayneIA, 11-27-2013 19:10:49
Sorry, my mistake.
One question- The newer replacement manifolds accept either the larger or smaller elbows for the muffler inlet side. If that is true of all the manifolds then would it not be possible to use the larger cast elbow on the muffler inlet, the larger pipe muffler (both of which are readily available) and then the rest of the arrangement for the x01 I described above?
Probably replacing too many parts but might work unless there is something else about the x00 series I am forgetting about. -Will
austin carpenter
11-27-2013 19:17:44
I think u are rite this is only for the 01 series.
lonestarjeff
11-28-2013 05:18:10
 Re: vertical exhaust ford 900 in reply to austin carpenter, 11-27-2013 19:17:44
Here's a parts diagram of the vert. exhaust kit showing the cast elbow(#8)...I pulled this off of the Partspring website under the 801 series, but I would think your 900 has the same upsized muffler outlet.
Copyright © 1997-2015 Yesterday's Tractor Co.
