Ford 800 3 point won't go up
Al07
New User
I recently had to pto shaft out and replaced the seal. I put oil back in and now the 3 point won"t move. Any ideas what might be wrong?
did you put oil back in both the rear end sump AND the hyd sump?
trans, rear, and hyds are 3 seperate sumps.. however pulling hte pto shaft out drains both the hyd and rear end sump.
Have you tried backing out the upper plug on the pump to clear out any bubbles? Do it while bumping the engine over w/ the starter(ignition off). I've lost pump pressure on my 860 when I did the pto seal.
Jeff
if a cylindrical pump, at the end.. there will be a plug onthe top side. may be inverted style plug and caked with dirt / hard to see.
