TractorLinks.com
Show Parts for Model:
Re: leaking excess fuel return line on 172-D
Texas!
11-25-2013 07:03:25
The line that is leaking was originally steel tubing as I recall. The 1/4" long piece of tubing that you are trying to connect the rubber hose to is probably all that's left of the original. It should be connected to the large fitting that screws into the bottom of the tank with a compression fitting. Remove the compression fitting and the short piece of tubing and take it to an auto parts store. They should be able to fix you up with a longer piece of tubing so that your rubber hose will have more tubing to slide over and get a good grip with a clamp.
