Yesterday's Tractor Co. Tractor Parts for All Brands
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
641 back fire in carb
LarryTN
11-24-2013 21:16:53
50.109.18.233
I have a 641 ford with 134 engine, just completed rebuilt engine about six month ago. It was running very good. I park it in the shed to clean up the ten. It sat there for about three months. Last wk I decided to use it for some hole digging When I started it up it began to pop and back fire in carb. First thing first, Checked Timing ok right on, check point they were clean an set @ .025, check plugs they clean and set @ .025 So next check compression all were 100-120 next check carb to make sure it wasn't set to lean.
all help will be appreciated
Thanks Larry
[Reply]   [No Email]
old
11-25-2013 09:23:15
209.86.226.19
 Re: 641 back fire in carb in reply to LarryTN, 11-24-2013 21:16:53
I would bet you have a sticking valve on the intake side. I would try putting a qt. of ATF in say 2 gal of gas and run it and see if it clears up
[Reply]  [No Email]
soundguy
11-25-2013 06:10:44
184.240.8.9
will it always backfire.. or only sometimes.
if 'always' then comp check should find it.
lastly.. check that rotor clip on the dizzy shaft.
post back
[Reply]  [No Email]
WayneIA
11-25-2013 01:42:20
199.120.65.45
Also check for moisture inside of the distributor cap.
[Reply]  [No Email]
rustytractorguy
11-24-2013 23:46:15
214.27.58.1
Gas that sits too long can varnish and get gummy. Fuel stabilizers can help lengthen fuels shelf life. I"ve been told, from multiple people, that gasoline shouldn"t sit for more then about 3 months as varnishing begins. That being said, you might have to drain the tank and put fresh gas in. The carb might have to be cleaned to.
[Reply]  [No Email]
JMOR
11-24-2013 21:30:09
72.181.173.171
 Re: 641 back fire in carb in reply to leeallen, 11-24-2013 21:16:53
Quoting Removed, click Modern View to seeCheck for sticking valve.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
