TractorLinks.com
Order Ford 4000 Parts Online
Re: Ford 4000 diesel won't run above idle speed
RodInNS
11-24-2013 19:22:31
What did you bugger with on the bottom of the pump? The 3/4" head cap screw on the advance piston? Until you said that I was going to suggest you drain the tank, remove the inlet strainer and clean it, then change the filter again. Now I'm not so sure...
I still suspect it's a supply issue and think you should rule that out first. Second would be a stuck metering valve... but usually you can't make them run if that's stuck.
Rod
