Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 3000 Parts Online
Re: Using 10% ethanol in Ford 3000
Pops1532
11-24-2013 08:05:35
There are two potential problems with ethanol. Rubber parts in older applications may not be compatible with ethanol. Your tractor probably has a steel fuel line. There were some issues with rubber tipped needle valves.
The other issue is ethanol absorbs moisture. Not a big deal if you run a lot of fuel through the system. It can be a problem if the vehicle or piece of equipment sits unused a lot.
Where ethanol causes the most problems is with vintage cars, or older small engines.
We've had E10 in my area since the mid 80's. I wish there was a non-ethanol option here. I still have a few older small engines that I'd use it in.
