TractorLinks.com
Order Ford NAA Parts Online
Re: Need help with remote pump coupler on NAA
old
11-23-2013 19:20:43
Well #1 that crank handle type bolt has to come off and be replaced with a normal bolt. #2 you have to have the correct pulley with the hole that line up for the drive hub to bolt to. So you may find your in for a bit of hard work
Spudly
11-23-2013 20:18:33
 Re: Need help with remote pump coupler on NAA in reply to old, 11-23-2013 19:20:43
1) Is there enough space to get a wrench in there and loosen the bolt?
2) Is it a normal thread or left hand thread.
3) Will a standard bolt work as replacement or do I need a special piece of Ford hardware?
Thanks,
Spud
old
11-23-2013 21:25:58
 Re: Need help with remote pump coupler on NAA in reply to Spudly, 11-23-2013 20:18:33
Normal tread as in right is tight left is loose. Yes you maybe able to remove it but it is at best a tight fit. As for tread if I remember right it is fine thread
Spudly
11-24-2013 18:54:31
 Re: Need help with remote pump coupler on NAA in reply to old, 11-23-2013 21:25:58
The rope in the spark plug hole did the trick. I used a large crescent wrench and a cheater bar to take off the ratchet nut. Now to find a regular nut as a replacement. Thanks for the help.
Spud
old
11-24-2013 21:07:40
 Re: Need help with remote pump coupler on NAA in reply to Spudly, 11-24-2013 18:54:31
Take the old one with you and match treads and how long it is and your good to go
