William Fissell
Hi,
640 hyds back togetyher, everything great, goes up, stays up, all good.
Come out today to brush hog. No up.
I loosen the pipe plug on the pump ("as usual") and let the air out... hyds come up slowly. Then. not at all.
Loosen pipe plug. nothing. Take pipe plug OUT with engine running. Nothing. Proofmeter shows RPMs. Pump will spit a drop now and then, no more.
Hydraulic fluid levels good by dipstick and overflow plug in diffy case.
I took the hydraulic pump off the and the fluid level in the return line on the manifold was a few inches below the oring.
Suggestions?
thanks in advance
Suggestions?
thanks in advance
