Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 3000 Parts Online
Re: Using 10% ethanol in Ford 3000
Tom in TN
11-23-2013 13:24:05
I use ethanol gas in everything that I own. I actually think that it is 15% ethanol. I use it in my Ford 2000 tractor, Husquvarna chain saws, pressure washer, both portable generators, Gravely walk behind mower, every lawnmower on the place, Echo brand string trimmers, all of my cars and trucks, and anything else that I've missed that has a gasoline engine on it.
I've never had a minute's trouble from the gas. I leave it in the fuel tanks through the winter, and have never had trouble in the spring when I get the tool back out.
Maybe I'm just lucky, but in my experience, the hoopla about ethanol is just that - hoopla.
Tom in TN
Sean in PA
11-24-2013 06:02:35
 Re: Using 10% ethanol in Ford 3000 in reply to Tom in TN, 11-23-2013 13:24:05
There has only been 10% ethanol around here for a long time, and I've been running everything on it with no ill effects.
15% ethanol was just approved by the EPA very recently, and it hasn't actually made it into any markets that I am aware of. I think that it is only approved for recent year cars and light trucks, not for off road equipment, motorcycles, boats or small engines, and they are working out the details on how it is to be labelled and dispensed. Their original idea was to allow blender pumps like they use now to blend regular and premium to get mid-grade, but instead it would be some method of blending the alcohol into the gas, but then actual tests were done and enough of the 15% alcohol fuel stays in the hose after pumping that they were going to require vehicles that it was not approved for to purchase a least 4 gallons of non-15% to guarantee that the alcohol level was low enough on that purchase to be safe for other other vehicle, but then someone pointed out to them that most motorcycles have fuel tanks smaller than 4 gallons, so now they're back at the drawing board.
E85, which is 85% ethanol has been on the market for a few years, and it is approved only for cars and light trucks that have been designed to use it. They usually have a badge on the rear of the vehicle that says "Flex-Fuel" or something like that.
Larry NCKS
11-23-2013 15:08:12
x2- I've used ethanol in all my gasoline engines since it first became available again back in the 70s. Not a bit of trouble I could blame on ethanol.
