Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
841 Governor how to test? Parts avail?
William Fissell
11-15-2013 05:55:50
129.59.115.13
Hi,
now that the 640 is on its wheels again, I am turning my attention to the 841 I just acquired. Needs lift cover overhaul, but more importantly it stalls under load
Starts. Runs, but as you let out the clutch with a bush hog on the back, it stalls. If you baby the clutch out slowly, it'll pick up rpms and run, unless you hit a patch of heavy stuff and then it dies.
I will go through the fuel system this weekend and probably service/overhaul the carburetor to eliminate that as a source f trouble; it has become my habit now to tear down, clean, and service the carb as the first or nearly first thing I do when I buy a new tractor. I seem to like doing it.
I do not know how to test the governor, short of tearing it down, too, which I do not wish to do unless absolutely necessary. Also, this site does not list repair parts for the governor, and its about $250 from CNH if available at all.
hints and suggestions welcomed.
Bill
[Reply]   [No Email]
showcrop
11-16-2013 09:43:44
75.67.231.80
 Re: 841 Governor how to test? Parts avail? in reply to William Fissell, 11-15-2013 05:55:50
When you get your owner's manual, (repros are readily available), somewhere around pages 53,54,55 is the section on adjusting the throttle linkage. You should go through that before digging into the governor.
[Reply]  [No Email]
gatcchelguy
11-16-2013 08:02:43
209.239.105.158
Check the throttle linkage. With the engine dead, the governor arm and the throttle shaft must reach wide open at exactly the same time. This is true of nearly all gas engines with mechanical governor.
[Reply]  [No Email]
TONY JACOBS
11-16-2013 00:14:52
172.164.11.235
Hello William , Since No New Parts brought it up and before you ask a 600/800 governor(ball type) and a 601/801 governor(flat roller type) are not the same . I have only had the 601/801 roller type just stick from sitting where as the 600/800 ball type will wear flat spots in the balls and will not work as JMOR says you feel the governor lever move back forth if it is free . Thanks Tony
[Reply]  [No Email]
William Fissell
11-16-2013 05:27:08
67.187.127.124
 Re: 841 Governor how to test? Parts avail? in reply to TONY JACOBS, 11-16-2013 00:14:52
Thank you!
[Reply]  [No Email]
NoNewParts
11-15-2013 07:36:39
67.240.141.151
after you get the ignition and carb straightened away,
governor-drive up and down a hill. should climb smoothly,
and try to slow you down going downhill.
Flatlander? with a healthy throttle setting, when you are
driving steadily along, step on both brakes. A 800's brakes are no match for an 800's motor
and good governor. It should give a roar and keep going.
[Reply]  [No Email]
JMOR
11-15-2013 07:06:39
72.181.173.171
Quoting Removed, click Modern View to seeYou can see & feel it in the linkage if a governor is doing something or not..hand & eyes are the tools.
[Reply]  [No Email]
William Fissell
11-15-2013 07:49:03
129.59.115.13
 Re: 841 Governor how to test? Parts avail? in reply to JMOR, 11-15-2013 07:06:39
thanks to both of you.
[Reply]  [No Email]
sunbeam
11-15-2013 17:02:57
70.195.68.157
 Re: 841 Governor how to test? Parts avail? in reply to William Fissell, 11-15-2013 07:49:03
Ebay has them for about $85
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
