4500 Hydraulic lift pump removal?
Guy Jeske
New User
I have a leak on the back side of the piston type lift pump where the hard lines attach, on a 1966 4500 3-cyl gas industrial tractor. This is the hyd pump located on the left rear of the engine that powers the 3-point lift. Do I have to remove the gas tank to access the attaching bolts, or is there a trick to access these bolts without tank removal? My manual has great detail on how to rebuild the pump, but no detail on remove and install.
Thank you in advance to the Ford experts here.
Others may have more accurate info on the industrial model,
But on a 68 3 cyl.deisel it's a little awkward but possible to get extension - swivel socket combination on those fasteners from the right side. After the hard line manifold is free the rest is a cakewalk. Keep track of the O- rings on that manifold.
