TractorLinks.com
Order Ford 640 Parts Online
Re: 640 broken fan, plot thickens, overheating
William Fissell
11-13-2013 08:33:37
yeah. Thought of the possibilty of a faceful of hot ethylene glycol.. yum...
I like the themostat idea. Would like to reurn it to service ASAP.. can you "exercise" them and get them back to work, or gotta replace?
soundguy
11-14-2013 12:00:20
 Re: 640 broken fan, plot thickens, overheating in reply to William Fissell, 11-13-2013 08:33:37
pull thermo.. reinstall top port... test as jmor said with ra cap off. will tell you if the pump is moving.
old
11-13-2013 13:59:38
Thermostats once locked up have to be replaced
William Fissell
11-13-2013 18:40:16
 Re: 640 broken fan, plot thickens, overheating in reply to old, 11-13-2013 13:59:38
popped it in a saucepan and heated it slowly. No open.
36 coupe
11-14-2013 06:17:24
 Re: 640 broken fan, plot thickens, overheating in reply to William Fissell, 11-13-2013 18:40:16
I have replaced many thermostats that were stuck shut and stuck open over the years.Testing in hot water with a meat thermometer is the only way.No boiling.Thermostats should just start to open at marked temperature.In the 50s we had a big coffee mug that had a heater and thermometer in it.It was common to use 160 thermostats in summer and change to 180 in winter for better defrosting.If you have had a thermostat stick open in winter you know what happens.A tuna can makes a good thermostat tester on an electric stove.
old
11-13-2013 20:34:06
Yep like I said once to hot they lock closed and so you get a hot running engine
William Fissell
11-13-2013 14:38:09
ordered
