Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: No spark
dyoungen
11-11-2013 19:58:15
I checked the coil by putting a plug in a plug wire and the other end of the plug wire in the coil. I had continual sparking, ie the points opening, as long as I was holding the key in the start position. I think I"ll replace the condenser at the same time since it doesn't cost that much.
Royse
11-11-2013 20:17:05
 Re: No spark in reply to dyoungen, 11-11-2013 19:58:15
If you have spark from the coil wire, leave the condenser alone for now.
Changing it is just another chance to introduce new problems.
Do you have spark on any plug wire? Check them all.
Do you have the correct wire core plug wires or auto style carbon wires?
Make sure the spring clip and rotor are on correctly and the
rotor doesn't hit the distributor cap as it turns.
Copyright © 1997-2015 Yesterday's Tractor Co.
