Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 600 Parts Online
Re: Ford 600
11-09-2013 14:07:52
Another possibility is the cast elbow for up exhaust that is still available that was standard for the XX1 series. The inlet to the elbow from the muffler may be larger than required for your 600 but that could be easily rectified with some sheet metal. They are a little pricey but I saw one sell on ebay awhile back for way more than you can get one for at CNH.
36 coupe
11-10-2013 03:08:04
 Re: Ford 600 in reply to showcrop, 11-09-2013 14:07:52
You dont need the cast elbow,properly bent exhaust pipe does away with it and saves 150 bucks.More money to spend on gasoline.
11-10-2013 03:52:19
 Re: Ford 600 in reply to 36 coupe, 11-10-2013 03:08:04
No, you don't "NEED" the cast elbow, but if you have your headlights on, getting the two bends in that short distance along with a flat surface for the clamp to bear on, is very difficult on many of the the pipe bending machines. I have had pipes bent for up out of the muffler, one worked OK, the other is hard to keep in place.
36 coupe
11-11-2013 15:43:18
 Re: Ford 600 in reply to showcrop, 11-10-2013 03:52:19
I have head lites and the pipe with proper bends.It can be done.
