Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: No spark
Sean in PA
11-09-2013 10:40:51
You said that it was converted to 12 volts. Is it set up as a negative ground system now? The original 6 volt system was positive ground, but most folks switch them to negative ground when they convert them to 12 volts. If it is negative ground, then the (-) terminal of the coil should go to the points. The (+) side of the coil should go to the key switch.
