Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 800 Parts Online
Re: 8000 ford
Sean in PA
11-09-2013 10:35:28
Check the line to that injector. It is probably clogged and causing too much back pressure which is causing the pump to not pump properly to any of the cylinders when the fitting on the line to that injector is tight. Loosening it and letting it leak means for sure that it's not firing on that one cylinder when it "runs good". It's got to be running on 5 cylinders when it's running. So once you solve the problem and get it to run with that line tightened down it's going to "run great" instead of "run good".
Copyright © 1997-2015 Yesterday's Tractor Co.
