TractorLinks.com
Order Ford NAA Parts Online
Re: running@idle oil pressure for a ford jubilee
36 coupe
11-09-2013 06:21:20
Take a look at the plate in the engine block next time you have the filter off.The hole in the plate should at 12 oclock.Dufus puts the plate in at 6 oclock so the oil drains out everytime the engine stops.I will NOT use a spin on filter on my tractor.
George Marsh
11-09-2013 20:55:58
 Re: running@idle oil pressure for a ford jubilee in reply to 36 coupe, 11-09-2013 06:21:20
My hole is at 12. Keep in mind my filter only drains half way back, even with the hole with threads that holds filter in place.
When I pull my filter, after sitting for a week, there is almost no oil dripping out of filter, unless I turn it upside down.
36 coupe
11-10-2013 02:41:48
 Re: running@idle oil pressure for a ford jubilee in reply to George Marsh, 11-09-2013 20:55:58
Oil comes from the oil pump to the outside of the filter and exits thru the center hole.Oil goes to the oil gallery from there.Theres a steel tube from the oil pump to the block that could be loose or cracked.Its been a long time but thats what I remember about the ohv oil system.
