Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: running@idle oil pressure for a ford jubilee
TimInd
11-08-2013 21:51:03
Ah, sorry, I don't believe those numbers for 2 reasons: 1.) You said those numbers are the same hot or cold. Can't be. Those numbers must go down when she heats up. 2.) Even on a new Jubilee engine, those numbers are too high. I would think replace the gauge and try again.
soundguy
11-09-2013 13:13:12
 Re: running@idle oil pressure for a ford jubilee in reply to TimInd, 11-08-2013 21:51:03
you are simply incorrect.
red tiger engines have a higher oil pressure relief cracking number than an N.
while a fresh N should top out around 45.. it's not uncommon to see 55-60 psi cold start throttle on a red tiger that is healthy.
Also not uncommon to see hot running pressures inthe 45-55 range for a healthy red tiger.
I've got about a dozen in the barn to back that up.
Bill Radford
11-10-2013 18:26:11
 Re: running@idle oil pressure for a ford jubilee in reply to soundguy, 11-09-2013 13:13:12
I agree> My 641 runs 55-60 psi steady. Does this with original and a test gauge. Has done this since I got it.
soundguy
11-11-2013 05:39:16
 Re: running@idle oil pressure for a ford jubilee in reply to Bill Radford, 11-10-2013 18:26:11
very, very common on a red tiger. when I see them with much less oil pressure.. i think oil and air fitler services were not done, and or it has a bajillion hours on it...
36 coupe
11-09-2013 05:51:42
I have a 640 that has run 50/60 pounds hot or cold for 27 years.Never say never.I have put new rod and main bearings in engines that hold steady pressure.
Copyright © 1997-2015 Yesterday's Tractor Co.
