TractorLinks.com
Order Ford NAA Parts Online
Re: running@idle oil pressure for a ford jubilee
soundguy
11-08-2013 17:04:05
she's showing wear.. but still has decades to go.
A GOOD healthy red tiger can generally maintain high 40's oil pressure at hot idle, and bump 60 cold throttle startup depending on oil viscosity and outside temps.
Your numbers are still fine.. that engine has just seen plenty of work
ejensen
11-08-2013 19:41:25
 Re: running@idle oil pressure for a ford jubilee in reply to soundguy, 11-08-2013 17:04:05
Thank you
ejensen
11-08-2013 19:38:13
Hi Rich,
Oil pressure at cold start up pins the gauge at 50lbs. Probably a replacement gauge as my 2n and 8n have gauges that go to 80psi. When opening up the engine to 1300-1500 rpm needle goes to 50 then back to 45 then up again. Probably the pressure relief valve opening@closing. Idles 20-25
old
11-08-2013 20:46:25
 Re: running@idle oil pressure for a ford jubilee in reply to ejensen, 11-08-2013 19:38:13
On many of these old tractor at idle any thing above 10 psi is bragging numbers. If you where talking a A/C tractor 10 is high at idle but then that is a horse of a different color
ejensen
11-09-2013 13:20:40
 Re: running@idle oil pressure for a ford jubilee in reply to old, 11-08-2013 20:46:25
As always your information is appreciated.
Chris
soundguy
11-09-2013 13:15:34
reminds me of my VAC. 15psi BOOK pressure is 100% normal.
when I got that VAC i thought she was sick,, but found out she was healthy!
