TractorLinks.com
Order Ford 5000 Parts Online
Re: FORD 5000 SOS TRANSMISSION
KURT PERRY
11-08-2013 15:31:57
It will roll with the coupler disengaged but not with the the coupler engaged. If it lost it's prime will idling it in park take awhile. or is there a way to prime it again. this may be the problem I had to put about 3 gallon of fluid back in to fill it up. When it is running it sounds like it wants to go into gear.
Larry NCKS
11-08-2013 15:48:03
 Re: FORD 5000 SOS TRANSMISSION in reply to KURT PERRY, 11-08-2013 15:31:57
This may be a useless question, but you did fill the transmission and not just the read end and hydraulics didn't you? The SOS transmission is a separate hydraulic reservoir from the hydraulics and rear end, even on a 5000.
KURT PERRY
11-09-2013 11:09:22
 Re: FORD 5000 SOS TRANSMISSION in reply to Larry NCKS, 11-08-2013 15:48:03
That may be the problem. What I filled was through a plug under the seat And the fill level plug was behind the axle. Where is the fill and the fill level plug for the transmission?
sunbeam
11-09-2013 13:52:31
 Re: FORD 5000 SOS TRANSMISSION in reply to KURT PERRY, 11-09-2013 11:09:22
There is a pipe plug on the right side in front of the brake pedals and to the rear of a 4 bolt servo cover.
Larry NCKS
11-09-2013 13:20:19
Most SOS fill/level plugs are on the right side, just ahead of and below the running board, Would guess 5000 to be there too, but not sure.
Texas!
11-09-2013 20:19:26
 Re: FORD 5000 SOS TRANSMISSION in reply to Larry NCKS, 11-09-2013 13:20:19
I removed the Check/Fill plug on my 5000 and replaced it with a "street ell" fitting. It is much easier to add fluid now.
