Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: No spark
Sean in PA
11-08-2013 09:56:44
If the points are sparking good every time they break apart as the distributor shaft turns, then the next place to look is the coil. As I said before, unhook the large wire from the center of the distributor cap but leave the other end connected to the coil, leave the free end of the wire near a good ground with the boot slid up so the copper connector is exposed, and try spinning the engine with the starter again. You should see a good blue/white spark that should jump at least a 1/4" gap from the end of that wire to ground every time you see the spark at the points. If you're not getting good spark at the high tension wire from the coil then either the coil is bad or the high tension wire is bad.
