Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 5000 Parts Online
Re: FORD 5000 SOS TRANSMISSION
sunbeam
11-08-2013 09:53:05
Can you still roll the tractor? If you can it's the coupler. If not start the tractor let it idle in park the trans may have lost prime.
KURT PERRY
11-08-2013 15:31:57
 Re: FORD 5000 SOS TRANSMISSION in reply to sunbeam, 11-08-2013 09:53:05
It will roll with the coupler disengaged but not with the the coupler engaged. If it lost it's prime will idling it in park take awhile. or is there a way to prime it again. this may be the problem I had to put about 3 gallon of fluid back in to fill it up. When it is running it sounds like it wants to go into gear.
Larry NCKS
11-08-2013 15:48:03
 Re: FORD 5000 SOS TRANSMISSION in reply to KURT PERRY, 11-08-2013 15:31:57
This may be a useless question, but you did fill the transmission and not just the read end and hydraulics didn't you? The SOS transmission is a separate hydraulic reservoir from the hydraulics and rear end, even on a 5000.
KURT PERRY
11-09-2013 11:09:22
 Re: FORD 5000 SOS TRANSMISSION in reply to Larry NCKS, 11-08-2013 15:48:03
That may be the problem. What I filled was through a plug under the seat And the fill level plug was behind the axle. Where is the fill and the fill level plug for the transmission?
sunbeam
11-09-2013 13:52:31
 Re: FORD 5000 SOS TRANSMISSION in reply to KURT PERRY, 11-09-2013 11:09:22
There is a pipe plug on the right side in front of the brake pedals and to the rear of a 4 bolt servo cover.
Larry NCKS
11-09-2013 13:20:19
Most SOS fill/level plugs are on the right side, just ahead of and below the running board, Would guess 5000 to be there too, but not sure.
Texas!
11-09-2013 20:19:26
 Re: FORD 5000 SOS TRANSMISSION in reply to Larry NCKS, 11-09-2013 13:20:19
I removed the Check/Fill plug on my 5000 and replaced it with a "street ell" fitting. It is much easier to add fluid now.
