TractorLinks.com
Order Ford 3000 Parts Online
Re: 3000 up running
Sean in PA
11-07-2013 05:43:24
I would assume that it's fairly low pressure in the return line. It is open to the vented tank at the end, so you will get flow but not a lot of pressure. In order to get high pressure you need a restriction to the flow. If the return line gets clogged and pressure does build in the return line the engine generally won't run well, if at all.
You should be able to use steel brake line, as many folks have used that to replace their power steering lines and the power steering creates more pressure than the return line should ever have.
Rustytractorguy
11-07-2013 07:07:36
 Re: 3000 up running in reply to Sean in PA, 11-07-2013 05:43:24
That"s a good point about the fuel tank mean event and therefore not having much pressure in the return line. I appreciate the commonsense as always!
