ejensen
Would like information regarding seals for main loader hydraulic cylinders on my Paulson loader which is on my ford jubilee. Where to buy them. I realize I could remove the cylinders, disassemble the cylinders and find out what seals are used .
Thanks
I don't know where you'd find that info. Paulson probably used any of several off the shelf cylinders on them.
I would do as you say and take them apart then head to your local hydraulic repair shop and see what they have.
Ultradog,
Sounds like a good plan. For your information the Paulson loader I bought fit perfectly on my jube. Had to install a flex coupling on the crankshaft pulley, removed the front end, and built a support for the pump. A lot of things I didn't know such as size of bolt for retaining the front pulley on the crankshaft. 1 1/4 nf. Thought I would put all the parts together needed with part numbers. Might help someone putting a Paulson loader on a ford jubilee. Many people on the forum such as yourself have helped me. Old has been a tremendous resource with this project. Bought the the loader on craigslist without seeing it when I was in Scottsdale Arizona from a tractor repair place in Shelton, Wa. Hauled the loader to the San Juan Islands where my tractor is located.
my loader and hoe seals on my antiques have all been found on the shelf at the local mom n pop hyds place. nothing weird. just v packing. sometimes the shop guy had to stack some packing due to minor differences in what was then and now.. but nothing was special order..
