Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 3000 Parts Online
Re: 3000 up running
Ultradog MN
11-07-2013 03:49:50
Good to hear you got it running.
As for the thermostart, just look at the intake manifold. If it has it it will have what looks kinda like a spark plug. The manifold below does boit have one - just has a flat plug where it would go.
To add it you would need the plug, the wiring and a small 1/8" metal tube that connects with a tee to the injector return line up by the fuel tank.
Just tighten the nut on the bottom of the throttle rod a couple/few turns to firm up the throttle handle. Assuming it still has the friction disc there. CNH is awful proud of those friction discs so I have made a couple out of leather from an old boot.
soundguy
11-07-2013 06:21:07
 Re: 3000 up running in reply to Ultradog MN, 11-07-2013 03:49:50
ditto on the boot!
remember back when you could buy bulk leather pieces and scraps. many pieces were the size of full sheets of paper and such. The last time I saw that was? 20+ ys ago. i still have 1-2 pieces in a bag that I cut up for stuff like that. even some custom OLD gaskets that were leather! ( we have an old littleford/etnyre asphalt (liquid) distribuiter machine that uses leather gaskets between the spray bar sections.
Ultradog MN
11-07-2013 06:25:34
 Re: 3000 up running in reply to soundguy, 11-07-2013 06:21:07
If you really want to be classy cut a piece out of one of your old Blue Suede Shoes. :)
FordTractorMan
11-07-2013 21:19:17
 Re: 3000 up running in reply to Ultradog MN, 11-07-2013 06:25:34
Looks like I've got it. Think I'll hook up my tester tomorrow and see if it's getting juice. Be getting cold before too long.
FordTractorMan
11-07-2013 06:15:03
Thanks, ultra. I'll check it out today.
rustytractorguy
11-07-2013 05:23:19
Here's a follow up question I had about the same thing. What is the PSI on the return side of the injector. CNH wants arms, legs, and your first born for the line ($400+) to the thermostart plug so I figure I'd create my own.
Ultradog MN
11-07-2013 06:20:02
 Re: 3000 up running in reply to rustytractorguy, 11-07-2013 05:23:19
I have an original line here but couldn't find it with a quick search.
I did find a pic of the glow plug in a 3600 manifold though. They are the same as the 3000.
As Sean says, there is no pressure on it.
I'm sure you could go to a hardware store and get everything you need.
About 3' of 1/8" copper tubing, a 1/8" compression fitting where it fits on the glow plug, an 1/8" Tee, about 12" of 1/8" fuel line and some hose clamps.
You could use steel line too but copper would suffice.
Cut the return line up near where it goes under the cowel and add the tee. Attach your new tubing then thread it down and along the top of the head to the glow plug.
Very, very easy task.
Hardware store will also have those little pinch open hose clamps like in the 2nd photo which I like for a neater job.
Ultradog MN
11-07-2013 06:22:49
 Re: 3000 up running in reply to Ultradog MN, 11-07-2013 06:20:02
On second thought, it might be 3/16" lines and fittings. Someone here will know.
Fordfarmer
11-07-2013 07:26:35
 Re: 3000 up running in reply to Ultradog MN, 11-07-2013 06:22:49
Yes, 3/16".
Rustytractorguy
11-08-2013 01:21:57
 Re: 3000 up running in reply to Fordfarmer, 11-07-2013 07:26:35
Just to verify 3/16 ID?
Copyright © 1997-2015 Yesterday's Tractor Co.
