TractorLinks.com
Order Ford 660 Parts Online
Re: ford 660
Kurt-NEPA
11-06-2013 15:42:43
Is it a tap or a knock? Its not uncommon to hear the lifters tap a bit as they take up the play in push rod/rocker arm/ valve train. Usually this does not go away, but might get better as things warm up.
My guess is that you are hearing a knock, probably from a worn rod bearing. In the early stages, this knock appears just a you start your engine and goes away as oil pressure builds. Take a look at your oil pressure gauge, does the knock stop as the pressure comes up?
If it is a knock, its a sign that an engine rebuild is in your future. Not a major problem as the 660 - 134 cu. in. Red Tiger engine is an easy rebuild. Well worth the effort
teddybolkas
11-07-2013 07:30:47
 Re: ford 660 in reply to Kurt-NEPA, 11-06-2013 15:42:43
Just bought the manual for rebuild. I hope it doesn't go that far!
