TractorLinks.com
Show Parts for Model:
Re: ID Sticker
Sean in PA
11-06-2013 10:03:26
Yup, the 4 in that position means 540 rpm independent PTO. You shouldn't get any grinding engaging the PTO with the clutch in any position, but they can be touchy so feather the handle to keep it from lurching when it engages. That PTO handle controls a hydraulic valve that controls both the PTO brake and the PTO clutch. In one position the brake is engaged and the clutch is disengaged, and in the other position the reverse is true. When you go to engage the PTO, move it slowly, and stop at the halfway to 2/3 point for a second or so before moving it the rest of the way and that should be the smoothest engagement without so much lurching. To find the right spot to stop the handle for the smoothest engagement, engage it and disengage it a few times with no implement hooked up and see at what point it grabs, and try to stop for a second just before the handle gets to that spot where it engages.
rustytractorguy
11-06-2013 10:11:02
 Re: ID Sticker in reply to Sean in PA, 11-06-2013 10:03:26
Thanks for the good tips!
