Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Ford 631 3 point lift arms - how low is normal?
11-06-2013 05:58:43
They do go pretty low, depends a bit on the tires on how close to the ground they go. No, there isn't really an adjustment.
That being said, you should have full control over the position of the arms in position control mode. Starting with the arms all the way down you should be able to move the touch control and set them at any particular level along the way. If you can do this, then the cam and follower pin inside the cover may be worn or out of adjustment.
In draft mode you will not be able to control the position of the arms as that is not what is intended. Moving the touch control off the top stop should drop the arms all the way down. In draft mode the touch control works to set the amount of "load" the implement exerts on the tractor. The tractor may raise and lower the implement to keep that same amount of "pull" on the tractor. It gets this input from the pushback on the center link.
So, long winded explanation, but if you cannot control your arms in their full range with position control, time to pull the cover.
11-06-2013 06:19:06
 Re: Ford 631 3 point lift arms - how low is normal? in reply to cbrown9064, 11-06-2013 05:58:43
Quoting Removed, click Modern View to seeYou told him that there is no adjustment for his problem (arms go 3-4 inches lower in draft than position), so............what is pulling the cover going to accomplish?
11-06-2013 18:59:52
 Re: Ford 631 3 point lift arms - how low is normal? in reply to jammison, 11-06-2013 06:19:06
If he has no resolution in the touch control, the pin and cam may be worn...
