pto flat belt pulley
Kirk-NJ
I have a pulley with numbers C5NNP746-A. Also Has FOMOCO on it. It's 1 3/8" I have tried to look it up but couldn't find it. It has a flang so it won't fit the 8n or hundred series. Maybe some of the square nose models???
Any help?
Thanks, Kirk
If by square nose you mean the 3 cyl Fords then no it wont fit those either.
2/3000, etc used the same belt pully as the Hundreds. Slightly different casting but interchangeable. It had to be for 1 3/8" pto of course.
Maybe it's for one of the Shibaura built Fords?
Dean,
I was thinking maybe a Dexta cause I seen a photo online that had the same flange. I think the Major had a side pulley but don't really know if it had both side and rear.
Kirk
