Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 5000 Parts Online
Re: 5000D regulator
soundguy
10-31-2013 06:36:25
the charging system is fine for those smart enough to work on them.
ford carge systems arte good.
lucas gennies are ok.. lucas vregs are sub standard. easy to swap a 'will fit' b circuit vreg from another application to a lucas gen and make it reliable.
ed1
10-31-2013 07:59:57
 Re: 5000D regulator in reply to soundguy, 10-31-2013 06:36:25
Ok, thank you guys for your input. I really appreciate it. I have decided to get the alt kit (250.00 from cheap tractor parts) in the interest of work and travel (60hrs plus week), 75 acres , 5 tractors, 3 pickup trucks, wife with 3 back surgeries, 86 year old Mother to take care of! It is a longer story, but you get the idea. Now I have to take battery out again and sandblast the tray and repaint it. That said I am looking for a permanent fix.
Thanks again,
Ed
RodInNS
10-31-2013 07:29:04
Someday... you will find out what those systems are really like....
It has absolutely nothing to do with how smart the repairman was or is. When you can repair/replace with 100% new today and in 3 weeks it quits working... and you do same again and again, sooner or later you smarten up and dump the misery.
I've got a 4000 here that's had at least 3 gens and countless regulators in my memory and the tractor is somewhat older than I am...
I do hear of the odd one that works and never gives trouble... and more often than not those are tractors stored in a shed that never get wet... and never do anything either.
Rod
soundguy
10-31-2013 08:09:43
 Re: 5000D regulator in reply to RodInNS, 10-31-2013 07:29:04
save it.
I've got PLENTY of gennies running.
If you now how to diagnose and troubleshoot simple Dc auto electrics.. you can keep them running. there is nothing but brushes, and contacts and springs going on.. it's not rocket science.
it's middle school science class stuff with magnetics...
Most people today can't wire a damn lamp. that's the problem....
RodInNS
10-31-2013 11:28:54
 Re: 5000D regulator in reply to soundguy, 10-31-2013 08:09:43
Save what??????? If you're implying that myself, Bern and various others don't know how to troubleshoot these things I'm afraid I've got some news for you..
It's you and a couple others that continue to lead folks down the garden path into believing that those ba$tard Lucas systems can be made to work reliably when the plain simply fact of the matter is that they can't. I've said this various times in the past... if you or others want to dick around with a useless, unreliable system that requires constant tinkering, go for it... and state it as such. IIRC, when you first acquired your 5000 you had some wiring rigged up so that you could repolarize the damn thing every time you started the tractor because it was doing exactly what all the others have done since time immemorial. Then you rigged a B circuit regulator to work on it... If you placed any value on your time you'd have been dollars ahead to install a Delco. If nothing else you'd have something that works when it's supposed to.
In the case of the original poster... he came here some time back, was bluntly told that he ought to install an alternator... and did not. Now he's got 3 gens and 3 regs to show for it, plus some wiring apparently... still doesn't have a working system and still won't until he installs the alternator. All done in the name of saving money, which it clearly has not.
As I said before, I've heard legends of Lucas electrics that never gave any trouble... one of them I found out myself to have not worked for many years, the owner not even knowing. The other one I know if wasn't exactly troublefree and it spent it's life in a heated garage. The rest... I don't know of a single one that ever worked reliably... and I've made doorstops out of a few myself. They're just junk. Always were; always will be.
Rod
soundguy
10-31-2013 18:34:11
 Re: 5000D regulator in reply to RodInNS, 10-31-2013 11:28:54
I didn't say YOU or Bern or any PARTICULAR other person couldn't troubleshoot them.
I know you and bern and many of the other question answer's here know how. I also know you have no tolerance for them.
I stopped reading your post closely after the first sentence after you jumped to the conclusion that I said you didn't know how to wire them.
I'm saying MOST people on this and other old tractor sites think anything with a wire is MAGIC.
PS... work on em right and you don't have to constantly tinker with them. take that however you want it.
Past a lil educational fun, and or testing I don't tinker with any of my genny or alt systems.
I have had a lucas reg come to me bad.. and have cleaned a few and then sealed up the cases.
they are still running.
I've got more ford electrical systems than lucas.. and I'm not taking up for the lucas VREG.. I think they are for sure the weak link in the system. the genny itself is nearly as robust as a ford one.. though I'd take a ford genny any day.
if you need mroe than 20a.. by all menas.. get an alt.
it a persons system is unreliable.. fix it. in most cases for a genny charge problem. it's EASY to positively ID if the genny has an issue.. or it is elsewhere. once you decide the genny is good 9 if it is ).. then it's gravy from there. ground or vreg are the common BIG issues.
I personally don't like lucas vregs. ihave in the past used ford vregs with no ill issues.
Again.
just because you don't like them doesn't mean they can't be made to work correctly.
i can think of plenty of good reasons to have a genny system over an alt. Most of them involve ham handed 'helpers and employees. ( those ones I mentioned that think electrons are magic.. and don't understand red vs black and positive and negative.
mix all that up and I have seen people kill alternators on a ford sinc ethey know 'all old fords are positive ground' as they burn out an alt hooking it up or jumping it wrong.
at most on a genny / vreg system..you toast a vreg. not the genny
nuf said.
and no.. I was not implying even covertly , that you do not know how to maintain one.
RodInNS
10-31-2013 19:58:40
 Re: 5000D regulator in reply to soundguy, 10-31-2013 18:34:11
I've never had any particular problem with the Motorcraft gens although there only was one to begin with. Lucas... we've dumped many. And no... I have absolutely no patience to deal with them. I simply look at it from the perspective that the time spent to convert them is well worth it. I do the same with Lucas alternators... and motorolla's...
The only soft spot I have is for Lucas starters. Those seem to be virtually indestructible other than needing the odd cleaning and brushes after a lot of use.
Rod
Regular Guy
10-31-2013 12:17:17
Please don't sling hot lead my way. Just been lurking on sidelines &reading and occurred to me to ask, beyond the Prince of Darkness origins, what hard specifics of these parts cause them to be unreliable, where millions of others by Auto lite, Delco, Ford, Datsun, on and on, worked for decades? I mean specifics beyond poor workman ship and crappy materials. What details of workmanship and which parts have bad materials and what materials. You get my drift by now. I really want to know exactly what details differ that makes these fail while others work. P.S. I be first to concede electronic more reliable than electromechanical, slip rings better than commutator, BUT that isn't what I'm pleading for amswers about. Thank you and answers from all will be appreciated.
Texas!
11-01-2013 13:28:59
 Re: 5000D regulator in reply to Regular Guy, 10-31-2013 12:17:17
According to my Generator (not Alternator) Man the Lucas gen is fine- it's the regulator that's junk.
RodInNS
10-31-2013 19:53:34
Wasn't directed at you...
Rod
soundguy
10-31-2013 18:40:23
when you look at a lucas vreg and genny.
the vreg is the weak link almost always.
they are not sealed well. get dirty inside.. sticky contacts..a nd they corode. you can mitigate it with a lil work.. if working on your tractor doesn't annoy you.
I much prefer ford electrics.
a ford b circuit 12v vreg from a prior diesel will run a lucas genny... etc..
Copyright © 1997-2015 Yesterday's Tractor Co.
