TractorLinks.com
Order Ford 2000 Parts Online
Re: 2000 gas no fire
JMOR
10-30-2013 07:48:52
Quoting Removed, click Modern View to seeSeeing as how your measurement/results do not add up, in my book anyway, I'll assume that a sensitive meter is yielding bogus conclusions. So used a 12v bulb test light & probe all those same places as well as directly from one point contact to the other, both with points open & points closed.
If you like sparks and arcs, I do, then quickly "sweep" a grounded wire across input to coil (spark means power good from ign sw), across distributor side of coil (points open or distr to coil wire disconnected) (spark means continuity thru coil). This last one should produce HV at coil tower.
