ford 4000 industral front mounted pump
I need help fining out what are the possible replacement parts for the shaft and couplers off the crankshaft to the front pump. this has a heavy looking shaft with all the coupling being casted parts. the engine hub is a 10 spline, with the pump being a 13 spline. is the MORFLEX coupler heavy duty enough or is there a different option that I have missed..
They sell all the parts you need on this Website. Parts are listed under Ford 4000 or 740 loader. I got all I needed to fix my 1963 4000 Industrial. I also used most of the same parts to make a new pump drive for my International 3414 that uses the same pump as the Ford with the 7/8" X 13 spline shaft.
A good place to start is the parts on this site, they carry Moreflex couplers and flanges in the hydraulic section - go to bottom. I also bought a shaft for my Ford 800 front pump here, don't see it under the 4000 section but if you poke around enough you might find.
Ford 4000 Moreflex
