Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 3000 Parts Online
Re: Ford 3000 engine mystery!
10-29-2013 12:36:22
Alright, now I'm very suspicious. The loader runs off of the tractor sump, not an external tank, nor off of the back-end 3 point sump.' But, just recently we had an 'expert hydraulic guy' replace the hydraulic pump because the loader quit working. The engine oil disappearance happened shortly afterwards. Is the seal kit/seal that you're referring to probably the one that we had replaced with the pump?
10-29-2013 13:26:04
 Re: Ford 3000 engine mystery! in reply to Savinsam, 10-29-2013 12:36:22
um.. clarify.
you said the laoder runs off the tractor sump.
but then you said it does not use the back end / 3pt sump.
clarify that.
the rear end and hyds are ommon on that tractor.
it either has a front stinger pump off the crank shaft snout and has it's own on loader sump. or it is run off the rear , side, engine mounted pump that uses hyds off the top cover.
what do YOU have?
