TractorLinks.com
Show Parts for Model:
Re: She ran, now she won't
RodInNS
10-29-2013 05:48:27
It's probably still air locked. Make sure there's a good flow of fuel coming out of the tank.... reconnect the line. Then remove the filter head bleeder and see what flow you have there with the engine quiet, then while cranking. You should at least get strong flow while cranking. If you have good flow, proceed to bleeding the lines at the injectors. If you don't, probably a bad lift pump. Once you start bleeding the lines, set the throttle to maximum and crank. Once you start getting some decent shots of fuel, close the lines up. If it still won't start, then put the ether to it. STOP dumping fuel into the intake. That's a recipe for disaster, particularly when you add ether. Loading an engine up with fuel and adding ether is how piston lands get blown off and connecting rods get bent....
At any rate, back to bleeding... put ether to it while cranking and regulate the ether bursts to the minimum amount required to make the engine run. When you get it running the lift pump should start moving enough fuel to self bleed...
Rod
