Show Parts for Model:
Re: She ran, now she won't
Brian Allen
10-28-2013 18:05:17
Did you get the tank cleaned out and fuel going to the lift pump?
It sounds like you have air in the system. The pump will not push fuel if there is any air in the supply line.
Purge the air at the bleed points, then tow the tractor until it runs. Or, just tow the tractor until it runs, but it may take a while.
10-29-2013 13:32:53
 Re: She ran, now she won't in reply to Brian Allen, 10-28-2013 18:05:17
I tried to keep it running on ether, but no love, the lift pump had me thinking as my dad had to replace it some 15 years ago when he acquired this compressor.
I have flow out of the rigged a fuel pressure gauge to the output of the pump, and have about 6/7 PSI.
Been searching, but can't find the pressure spec's for it.
I guess I should take it apart and see if the diaphragm ruptured when I had it running before.
PS, I did drain the tank the best I could, there was no crud floating in it and no rust that I could see with my flashlight.
