Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 601 Parts Online
Re: my ford 601 workmaster fuel shut off valve inder tank
10-23-2013 15:19:32
Bill, Their are 2 "O" ring seals involved with the valve.One is between the tank and valve itself.The other is on the stem.If the rivet is not installed in it's hole and the stem with it's seal is backed out past the hole it will leak.You don't need to remove the tank to remove/reinstall the valve.Just empty the tank, disconnect the fuel line and remove the 2 bolts holding the valve.
Bill Allis
10-24-2013 08:36:49
 Re: my ford 601 workmaster fuel shut off valve inder tank in reply to GVSII, 10-23-2013 15:19:32
OK, Thanks. The tractor is 1200 miles away, so I can't look at it. Didn't think there was enough room to remove it with the tank on. I put a new tank on and at least 2 new valves and they still leak. Got to fix it right.
