TractorLinks.com
Show Parts for Model:
Re: ford 900 loader wont lift weight
Larry NCKS
10-23-2013 03:29:35
You have problems in your tractor somewhere. Could be a leak. Could be a pressure relief valve. Could be your pump. Do you hear any squealing under your seat when trying to lift? That would likely be your relief valve or a leak. Kinda hard to tell with no more than I know from this distance.
An observation: There should not be pressure on your #1 drop port if you're running single acting cylinders on #1. There ought to be a screw or a stem on that valve to change #1 from double acting to single acting operation. I know there is on single spool valves.
soundguy
10-23-2013 05:55:07
 Re: ford 900 loader wont lift weight in reply to Larry NCKS, 10-23-2013 03:29:35
i know on many dual da spools, they have the option to turn only one side to sa.
all of my 'ford' style have that. even the tisco repops.
truge
10-23-2013 11:14:19
 Re: ford 900 loader wont lift weight in reply to soundguy, 10-23-2013 05:55:07
appears someone before me had 1 and 2 single acting cyls into the lift and drop ports coupled one and two togather and pluged into no 1 lift left no. 2 drop empty works like new the cyls were fighting against each other thanks for all the ideas and help you guys are great
Larry NCKS
10-23-2013 17:42:50
 Re: ford 900 loader wont lift weight in reply to truge, 10-23-2013 11:14:19
Glad u got it figured out.
